XRT install error on centos8.1
hi everyone
when i install Xilinx Runtime(XRT) on centos8.1, it reported an error :
Then I looked at ug1451 XRT release- notes.pdf , found that it supports 7.4, 7.5, 7.6 versions of CentOS
But I installed CentOS 8.1, which is supported by Vitis.
What I want to ask is whether the above error is caused by the version ?
Can XRT be installed on CentOS 8.1 ?
Hi @avcon_lee
It seems that you need to add some related package files.
Would you find proper packages by "yum whatprovides" and install them by "yum install" command ?
Best regards,
XRT of v2020.1 PU1 can be supported in CentOS 8.1.
@hongh
thanks,So do you know how to solve the above mistakes
Please try the new XRT.
https://www.xilinx.com/products/boards-and-kits/alveo/u50.html#gettingStarted
@hongh
Still not, but the number of errors is less
Hi @avcon_lee
Best regards,
@watari
I tried, But it didn't work.
I found this posthttps://forums.xilinx.com/t5/Alveo-Accelerator-Cards/Install-Alveo/m-p/1131102#M1899
Considering that petalinux needs to be installed later (judging from ug1144, CentOS 8.1 is not supported),
so I decided to install Ubuntu 18.04, which is supported by Vitis, XRT and petalinux
@watari
I found the corresponding software package from the Internet, and now XRT has been installed successfully
