dheeraj141
Xilinx vitis HW build stuck
I have been trying to build the actual hardware Xilinx vitis on the fpga but the compilation process is stuck. I ran it for like 16 hours but it is not moving forward beyond this point.
INFO: [v++ 60-585] Compiling for hardware target
INFO: [v++ 60-423]   Target device: xilinx_u280_xdma_201920_3
INFO: [v++ 60-242] Creating kernel: 'krnl_vadd'
I am running it for matrix size of 512*512.
Can any one please point out the cause for this.  I have attached the log also.
nutang
Hi @dheeraj141
In order to get additional debug logs, you need to configure XRT to do so.
Please create xrt.ini file inside the executable folder.
Write below content
#Start of Runtime group
[Runtime]
verbosity = 7
Here is the reference
https://xilinx.github.io/XRT/master/html/xrt_ini.html
Please run the application again and share the additional logs to debug it further.
Best Regards,
Nutan
