ZCU104 video capture with opencv library issue???
I would like to capture video with cv::videocapture cap(0) function, and then do the image processing.
The code like this:
#include<opencv2/core/core.hpp>
#include<opencv2/highgui/highgui.hpp>
#include<opencv2/video/video.hpp>
cv::VideoCapture cap(0);
However, the following errors pop up when I compile the code:
C:/taosdsoc/tao_hog/test/tao_test/Release/src/xf_hog_descriptor_tb.o: In function `main':
xf_hog_descriptor_tb.cpp:(.text.startup+0x74): undefined reference to `cv::VideoCapture::VideoCapture()'
xf_hog_descriptor_tb.cpp:(.text.startup+0x80): undefined reference to `cv::VideoCapture::open(int)'
xf_hog_descriptor_tb.cpp:(.text.startup+0x9ac): undefined reference to `cv::VideoCapture::~VideoCapture()'
xf_hog_descriptor_tb.cpp:(.text.startup+0x9e4): undefined reference to `cv::VideoCapture::~VideoCapture()'
I am not sure what is reason for the errors?
Thank you in advance.
It seems that you didn't link OpenCV in project settings,
It is unable to find API declaration.
Please check your include path.
C/C++ settings->C/C++ General->Paths and symbols
check for warning sign on include paths
Best Regards,
Nutan
Best Regards,
Nutan
Hi nutang,  thanks for your message!
Here is the error message!
collect2.exe: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'aarch64-linux-gnu-g++
the compile pops up errors when calling aarch64-linux-gnu-g++
Hi lulugay,
Thanks for your reply.
The solution perfectly works for my project.
I was having the same problem and followed the solution but I am still having a linker problem as following
H:/Xilinx/work/zed_test/src/main.cpp:13: undefined reference to `cv::VideoCapture::retrieve(cv::Mat&, int)'
H:/Xilinx/work/zed_test/src/main.cpp:14: undefined reference to `cv::_InputArray::_InputArray(cv::Mat const&)'
H:/Xilinx/work/zed_test/src/main.cpp:14: undefined reference to `cv::imshow(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, cv::_InputArray const&)'
Could you please provide some details of how you have solved this issue?
I am using zcu102 with SDSoC (2017.4) in windows 10.
