meet.bais
ZYBO BOARD FOR SDX 2018.3
Hello
I am trying to use SDx 2018.3
However, it does not have ZYBO board in it's platform directory. How do i add the ZYBO board and process with the same.
Help needed.
nutang
Hi @meet.bais
First thing is to create a hardware(dsa) and software components(petalinux build) for your board.
Later you need to create a platform for your board.
And then after the platform generation is successful, you can write applications/libraries etc
Here is the guide for platform creation - https://github.com/Xilinx/SDSoC-Tutorials/blob/master/platform-creation-tutorial/README.md
Best Regards,
Nutan
dpaul24
@meet.bais,
Try this...
The Zybo board has a particular Xilinx FPGA. Use that part number for adding.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
nutang
Hi @dpaul24
No, That is not the correct way.
User has to create a platform if it is not present
Here is the list of already existing platforms
https://www.xilinx.com/products/design-tools/software-zone/sdsoc.html#boardskits
Best Regards,
Nutan
