qubits1
Zynq 7000 Vitis platform can't read zynq_fsbl.elf
I'm following this blog post https://www.hackster.io/news/microzed-chronicles-microzed-zynq-7000-vitis-platform-creation-df25e1054fb6
and when I try to build vector addition system (from template) I get the following error message
make all
Generating bif file for the system project
Executing command '::scw::generate_bif -xpfm /home/qubits/proj/microzed_pkg/pfm/wksp1/microzed/export/microzed/microzed.xpfm -domains linux_domain -bifpath /home/qubits/proj/microzed_pkg/pfm/wksp1/hello_system/Debug/system.bif' on XSCT
sdcard_gen --xpfm /home/qubits/proj/microzed_pkg/pfm/wksp1/microzed/export/microzed/microzed.xpfm --sys_config microzed --bif /home/qubits/proj/microzed_pkg/pfm/wksp1/hello_system/Debug/system.bif --no_bitstream --sd_file /home/qubits/proj/microzed_pkg/pfm/wksp1/hello/Hardware/hello.exe
Running /media/qubits/tb3/Tools/Xilinx/Vitis/2019.2/bin/bootgen  -image /home/qubits/proj/microzed_pkg/pfm/wksp1/hello_system/Debug/sd_card_temp/boot.bif -w -o i BOOT.BIN
[ERROR]  : Can't read file - zynq_fsbl.elf
Error writing SD card data : Error when running '/media/qubits/tb3/Tools/Xilinx/Vitis/2019.2/bin/bootgen  -image /home/qubits/proj/microzed_pkg/pfm/wksp1/hello_system/Debug/sd_card_temp/boot.bif -w -o i BOOT.BIN'
make: *** [makefile:39: sd_card] Error 1
I have specified the linux.bif as follows:
/arch = zynq; split = false; format = BIN
the_ROM_image:
	[bootloader]/home/qubits/proj/microzed_pkg/pfm/boot/zynq_fsbl.elf
	/home/qubits/proj/microzed_pkg/vivado/accl_prj/accl_prj.runs/impl_1/block_design_wrapper.bit
	/home/qubits/proj/microzed_pkg/pfm/boot/u-boot.elf
and verified that the zynq_fsbl.elf exists at that location.
What could be the issue here?
qubits1
Fixed. It worked after I rebuilt the microzed platform project
qubits1
