guy.berger
can't find linked library
I'm using Vitis 2019.2 and can't seem to link a .a file library to the porject.
Thanks for any help!
nutang
Hi @guy.berger
If you mentioned it as tx and if library search path is correct then please check if the library is 64bit
Best Regards,
Nutan
hokim
-l  should be followed by not libtx.a but tx
guy.berger
Still not working.. can't find
nutang
Hi @guy.berger
Best Regards,
Nutan
