drand48 in hls
I am trying to compile a function that uses drand48() function to generate uniformly distributed pseudo-random numbers, but when I tried to accelerated this function I get the next error
function 'drand48' has no function body.
Is there any available function in sdsoc/hls to generate uniformly distributed numbers over the interval [0.0,1.0) ?
Jorge
Mentor
Mentor
Re: drand48 in hls
Generating uniformly distributed numbers over a range is trivial; a simple counter will do that. For something that looks random, a linear feedback shift register is both inexpensive and easy to implement - but not really random. For true randomness, you can build a circuit that deliberately "fails" timing (can't do this in HLS, have to use HDL) and with suitable processing this can deliver genuinely random numbers.
Mentor
Mentor
Re: drand48 in hls
