erfc and erf build in functions
I have used erfc() in my kerneland I am using SW_Simulation.
for (int i = 0 ; i < n_elements ; i += BUFFER_SIZE)
    {printf("%f\n", erfc(0.35));}
the program runs but the result is just like the bellow lines. the first 0.0 output and a lot of Nan out put. What should I do? could you please help me?
0.000000
-nan
-nan
-nan
-nan
Hi,  @ramin_rasoulinezhad ,
Have you tried SDx 2018.2?  I don't see the issue in 2018.2 with erfc and erf.
Another try:
for (int k=+100;k>-100;k--){
        ali = erfc(k * 0.01);
        printf("&&%g\n", ali);
output:
&&-5.48613e+303
&&-5.48612e+303
&&-5.48612e+303
&&-5.48612e+303
&&-5.48612e+303
.... (just like the last one)
Which version of sw are you using?
Have you tried the latest version of sw?
Please share more code for us to reproduce the issue.
I am using 2017.2. Is it OK?
In this version, all the mathematic functions work except erf and erfc.  Which version do you recommend? I am downloading 2018.2 now
Ramin
Please check whether the issue can still be seen in 2018.2(The latest Version is recommended)
