error while building CHaiDNN project on ZCU102
When I compile the program according to the steps described in the Creating SDx GUI Project.md file,the following error occurs. How can I solve it?
/home/lx/xilinx_dnn/CHaiDNN/src/design/conv/src/xi_convolution.hpp:1903:38: [ skipping 4 instantiation contexts, use -ftemplate-backtrace-limit=0 to disable ]
Re: error while building CHaiDNN project on ZCU102
Hi  @zxyglx_,
It is hard to tell you what could be wrong with just that picture. Whereas one could guess, as you are using the GUI mode, and because the compiler is showing 4 instantiation error contexts which are exactly the same as the 4 examples that came in the CHaiDNN, and those should not be compiled at the same time (which appears in the documentation), and therefore removing the other 3 sources could be the solution. It is still a vague guessing.
Please attach the log of your run, so we can see how we can help you in a better way.
Regards!
/* Don't forget to give kudos and/or accept as a solution */
Hi  @zxyglx_,
Regards!
The problem was solved,but other problems occur.Finally, CHaiDNN was built successfully using Makefiles.Thank you!
Hi @zxyglx_
How did you manage to solve them ?
ML
You can use Makefiles to build.However,memory consumption is very large when compiled.An error may occur due to insufficient memory.
Did you use makefiles to solve the skipping instanciations issues or to solve others issues you mentioned in a previous comment ?
How did you solve this problem?
