Ztone
fatal error:ap_int.h:No such file or directory
I use Vitis 2019.2 version, zcu104 board, Vitis Libraries2019.2 version.
When building HW-EMU, the following error occurred
build errorbuild error
The example is referenced from Vitis_Libraries-2019.2/vision/L2/examples/resize
What should be done when Vitis Libraries is developing on zcu104 and why the above error occurs??
I found the ap_int.h file in the /tools/Xilinx/Vitis/2019.2/include folder,Should I specify this path on GCC Compiler? I tried it, but this is not possible.
How to solve this problem??
Thanks your review and reply!!!!
