g_sai
file not found in vitis hls for linehandler in U50 accelerator
I am trying to do C Synthesis of line handler in U50 Accelerator. C Simulation is done successfully. it is showing
Starting C synthesis ...
/tools/Vitis/Vitis_HLS/2020.2/bin/vitis_hls /home/iiitb/0internship/hls_projects/linehandler_ports/solution1/csynth.tcl
INFO: [HLS 200-10] Running '/tools/Vitis/Vitis_HLS/2020.2/bin/unwrapped/lnx64.o/vitis_hls'
INFO: [HLS 200-10] For user 'iiitb' on host 'iiitb' (Linux_x86_64 version 5.8.0-50-generic) on Wed May 05 12:31:13 IST 2021
INFO: [HLS 200-10] On os Ubuntu 20.04.2 LTS
INFO: [HLS 200-10] In directory '/home/iiitb/0internship/hls_projects'
Sourcing Tcl script '/home/iiitb/0internship/hls_projects/linehandler_ports/solution1/csynth.tcl'
INFO: [HLS 200-1510] Running: open_project linehandler_ports
INFO: [HLS 200-10] Opening project '/home/iiitb/0internship/hls_projects/linehandler_ports'.
INFO: [HLS 200-1510] Running: set_top lineHandlerTop
INFO: [HLS 200-1510] Running: add_files ../../Accelerated_Algorithmic_Trading_modified/hw/common/include/aat_defines.hpp
INFO: [HLS 200-10] Adding design file '../../Accelerated_Algorithmic_Trading_modified/hw/common/include/aat_defines.hpp' to the project
INFO: [HLS 200-1510] Running: add_files ../../Accelerated_Algorithmic_Trading_modified/hw/common/include/aat_interfaces.cpp
INFO: [HLS 200-10] Adding design file '../../Accelerated_Algorithmic_Trading_modified/hw/common/include/aat_interfaces.cpp' to the project
INFO: [HLS 200-1510] Running: add_files ../../Accelerated_Algorithmic_Trading_modified/hw/common/include/aat_interfaces.hpp
INFO: [HLS 200-10] Adding design file '../../Accelerated_Algorithmic_Trading_modified/hw/common/include/aat_interfaces.hpp' to the project
INFO: [HLS 200-1510] Running: add_files ../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler.cpp
INFO: [HLS 200-10] Adding design file '../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler.cpp' to the project
INFO: [HLS 200-1510] Running: add_files ../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler.hpp
INFO: [HLS 200-10] Adding design file '../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler.hpp' to the project
INFO: [HLS 200-1510] Running: add_files ../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler_kernels.hpp
INFO: [HLS 200-10] Adding design file '../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler_kernels.hpp' to the project
INFO: [HLS 200-1510] Running: add_files ../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler_top.cpp
INFO: [HLS 200-10] Adding design file '../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler_top.cpp' to the project
INFO: [HLS 200-1510] Running: add_files -tb ../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/test/tb_linehandler.cpp
INFO: [HLS 200-10] Adding test bench file '../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/test/tb_linehandler.cpp' to the project
INFO: [HLS 200-1510] Running: open_solution solution1 -flow_target vivado
INFO: [HLS 200-10] Opening solution '/home/iiitb/0internship/hls_projects/linehandler_ports/solution1'.
INFO: [SYN 201-201] Setting up clock 'default' with a period of 3.33ns.
INFO: [HLS 200-10] Setting target device to 'xcu50-fsvh2104-2-e'
INFO: [HLS 200-1505] Using flow_target 'vivado'
Resolution: For help on HLS 200-1505 see www.xilinx.com/cgi-bin/docs/rdoc?v=2020.2;t=hls+guidance;d=200-1505.html
INFO: [HLS 200-1510] Running: set_part xcu50-fsvh2104-2-e
INFO: [HLS 200-1510] Running: create_clock -period 3.33 -name default
INFO: [HLS 200-1510] Running: csynth_design
INFO: [HLS 200-111] Finished File checks and directory preparation: CPU user time: 0.01 seconds. CPU system time: 0 seconds. Elapsed time: 0.01 seconds; current allocated memory: 240.074 MB.
INFO: [HLS 200-10] Analyzing design file '../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler_top.cpp' ...
ERROR: [HLS 207-812] 'aat_defines.hpp' file not found: ../../Accelerated_Algorithmic_Trading_modified/hw/lineHandler/linehandler.hpp:22:10
INFO: [HLS 200-111] Finished Command csynth_design CPU user time: 0.19 seconds. CPU system time: 0.06 seconds. Elapsed time: 0.43 seconds; current allocated memory: 240.387 MB.
command 'ap_source' returned error code
while executing
"source /home/iiitb/0internship/hls_projects/linehandler_ports/solution1/csynth.tcl"
invoked from within
"hls::main /home/iiitb/0internship/hls_projects/linehandler_ports/solution1/csynth.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$newargs"
(procedure "hls_proc" line 16)
invoked from within
"hls_proc [info nameofexecutable] $argv"
INFO: [HLS 200-112] Total CPU user time: 8.18 seconds. Total CPU system time: 1.54 seconds. Total elapsed time: 6.95 seconds; peak allocated memory: 240.074 MB.
Finished C synthesis.
but I have added this file aat_defines.hpp . It is showing an error. Please help me
Thanks in advance
