hls::CvtColor & xf::Threshold
Can somebody build a simple project successfully in Sdx ISE which just need read an image and convert its color space to gray using hls::CvtColor and then use xf::Threshold to get the result ? I failed.
Hi @wd-hyj,
Yes, you are right that HLS video functions cannot be synthesized for hardware in SDSoC, as they have hls::streams at interface level which are not supported by SDSoC.
But, the good news is, all the HLS Video Library functions have been ported to xfOpenCV in 2018.3 version. So, whatever the HLS video function that you intend to use, is now available in the xfOpenCV library with a synthesizable xf::Mat interface.
I have built the following code in Sdx successfully.
#include "opencv2/opencv.hpp"
#include "opencv2/highgui/highgui.hpp"
#include "opencv2/imgproc/imgproc.hpp"
//#include "sds_lib.h"
#include "/home/jumper/FPGA_projects/HLS2018.2/xiangAn_wd/xfOpenCV/include/common/xf_sw_utils.h"
#include "xf_myxf_accel.h"
int main(int argc, char** argv)
	cv::Mat in_img,in_img1,out_img,ocv_ref;
	cv::Mat in_gray,in_gray1,diff;
	// reading in the color image
	in_gray = cv::imread("./data/im0.jpg", 0);
	if (in_gray.data == NULL)
		fprintf(stderr,"Cannot open image\n");
		return 0;
	static xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> imgInput(in_gray.rows,in_gray.cols);
	static xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> imgOutput(in_gray.rows,in_gray.cols);
	static xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> threshimgtb(in_gray.rows,in_gray.cols);
	static xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> dilateimgtb(in_gray.rows,in_gray.cols);
#pragma SDS data copy(in_gray.data)
	imgInput.copyTo(in_gray.data);
	myxffun(imgInput,threshimgtb,dilateimgtb, imgOutput);
	// Write output image
	xf::imwrite("hls_out.jpg",imgOutput);
	return 0;
But i rebuilt it failed when it changed to the following :
#include "opencv2/core/core.hpp"
//the following two hpp can only be included in testbench!!!!!!!
#include "/home/jumper/FPGA_projects/HLS2018.2/xiangAn_wd/xfOpenCV/include/common/xf_infra.h"
//why can't include these following head file?!
#include "hls_opencv.h"
#include "hls/hls_video_arithm.h"
#include "hls/hls_video_types.h"
#include "hls/hls_video_core.h"
#include "hls/hls_video_imgproc.h"
	in_gray = cv::imread("./data/im0.jpg",0);
		return 0;
	//hls video function can only be here ?!
	hls::stream<ap_axiu<24,1,1,1> > bgr_src;
	cvMat2AXIvideo(in_gray, bgr_src);
	hls::stream<ap_axiu<24,1,1,1> > bgr_scaleimg;
	hls::Mat<HEIGHT,WIDTH,HLS_8UC3> bgr_src_mat(HEIGHT,WIDTH);
	hls::Mat<HEIGHT,WIDTH,HLS_8UC3> bgr_scaleimg_mat(HEIGHT,WIDTH);
	hls::Scale(bgr_src_mat,bgr_scaleimg_mat,1.5);
	hls::Mat<HEIGHT,WIDTH,HLS_8UC1> grayimg;
	hls::CvtColor<HLS_BGR2GRAY>(bgr_scaleimg_mat, grayimg);
//	hls::stream<ap_axiu<24,1,1,1> > bgr_src;
//	cvMat2AXIvideo(in_gray, bgr_src);
//	hls::stream<ap_axiu<8,1,1,1> > grayimg;
//	hlsfun(bgr_src,grayimg);
//	xf::AXIvideo2xfMat(grayimg,imgInput);
	xf::imwrite<TYPE,HEIGHT,WIDTH,NPC1>("hls_out.jpg",imgOutput);
//	cv::Mat dstimg(HEIGHT,WIDTH,CV_8UC1);
//	dstimg.data=imgOutput.copyFrom();
//	cv::imwrite("debug.jpg",dstimg);
	return 0;
the error information is :
Preliminary link application ELF
/home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/swstubs/xf_myxf_tb.o:在函数‘void xf::imwrite<0, 1080, 1920, 1>(char const*, xf::Mat<0, 1080, 1920, 1>&)’中:
xf_myxf_tb.cpp:(.text._ZN2xf7imwriteILi0ELi1080ELi1920ELi1EEEvPKcRNS_3MatIXT_EXT0_EXT1_EXT2_EEE[_ZN2xf7imwriteILi0ELi1080ELi1920ELi1EEEvPKcRNS_3MatIXT_EXT0_EXT1_EXT2_EEE]+0x2dc):对‘cv::_InputArray::_InputArray(cv::Mat const&)’未定义的引用
xf_myxf_tb.cpp:(.text._ZN2xf7imwriteILi0ELi1080ELi1920ELi1EEEvPKcRNS_3MatIXT_EXT0_EXT1_EXT2_EEE[_ZN2xf7imwriteILi0ELi1080ELi1920ELi1EEEvPKcRNS_3MatIXT_EXT0_EXT1_EXT2_EEE]+0x2fc):对‘cv::imwrite(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, cv::_InputArray const&, std::vector<int, std::allocator<int> > const&)’未定义的引用
/home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/swstubs/xf_myxf_tb.o:在函数‘void hls::arithm_pro<hls::kernel_scale, 1080, 1920, 4096, unsigned char, 4096, double, double, double>(hls::Mat<1080, 1920, 4096>&, hls::Scalar<(((4096)&(((512)-(1))<<(11)))>>(11))+(1), unsigned char>, hls::Mat<1080, 1920, 4096>&, double, double, double)’中:
xf_myxf_tb.cpp:(.text._ZN3hls10arithm_proINS_12kernel_scaleELi1080ELi1920ELi4096EhLi4096EdddEEvRNS_3MatIXT0_EXT1_EXT2_EEENS_6ScalarIXplrsanT2_lsmiLi512ELi1ELi11ELi11ELi1EET3_EERNS2_IXT0_EXT1_EXT4_EEET5_T6_T7_[_ZN3hls10arithm_proINS_12kernel_scaleELi1080ELi1920ELi4096EhLi4096EdddEEvRNS_3MatIXT0_EXT1_EXT2_EEENS_6ScalarIXplrsanT2_lsmiLi512ELi1ELi11ELi11ELi1EET3_EERNS2_IXT0_EXT1_EXT4_EEET5_T6_T7_]+0xac):对‘hls::__isnan(double)’未定义的引用
/home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/swstubs/xf_myxf_tb.o:在函数‘main’中:
xf_myxf_tb.cpp:(.text.startup+0x218):对‘cv::imread(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int)’未定义的引用
xf_myxf_tb.cpp:(.text.startup+0x32c):对‘cv::Mat::operator _IplImage() const’未定义的引用
collect2: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++    /home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/swstubs/xf_myxf_accel.o /home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/swstubs/xf_myxf_tb.o /home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/swstubs/portinfo.o -L/home/jumper/workspace/xilinx_opencv_3.4.1/lib -lopencv_world   -L /opt/Xilinx/SDx/2018.2/target/aarch32-linux/lib -L/home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/swstubs -Wl,--start-group  -Wl,--end-group -Wl,--start-group    -lpthread -lsds_lib -lxlnk_stub  -Wl,--end-group -o /home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/swstubs/HLSxfOpenCV.elf'
make: *** [HLSxfOpenCV.elf] Error 1
sds++ log file saved as /home/jumper/FPGA_projects/sdsoc2018.2/HLSxfOpenCV/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
makefile:45: recipe for target 'HLSxfOpenCV.elf' failed
I really do not know the reason.
Hi @wd-hyj
Please navigate to C/C++ build settings -> C/C++ General->Paths and Symbols
In Includes tab, Under GNU C++, Add below include path,
<revision platform folder path>/zcu104-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include
Best Regards,
Nutan
Best Regards,
Nutan
Thanks for your reply!Unfortunately, The error information was still the same after i added "/opt/Xilinx/zcu102_rv_ss/sw/sysroot/usr/include". Well,someone told me "HLS video function only supports simulation but not for synthesization so the error will occur when you use hls video function in Sdx!" ,is that right? Did you see someone uses hls video function in Sdx ? I haven't.
Hi @wd-hyj,
Really?thant's really a good news! I am considering to update my Sdx version!
