mkachar
how to run *.xcllbin file without host calling the file!
Hi all,
I recently generated a '*.xclbin' file starting from Vivado_HLS (vitis bottom top approach). My question, is it really required to generate a host file so as to accept this .xclbin file to run on my targetted platform, cant i just run the .xclbin file?
If there is any way to do this please let me know.
graces
The .xclbin is FPGA binary for kernel code. This is in the context of application accelaration.
If you would like to run something in the hardware alone, you need to turn to the standard HLS+Vivado flow, which generates bitstream.
hongh
You have to call kernel logic in FPGA with a host code.
graces
