how to search like in the old SDK in all open projects?
In the old SDK I used to Use Alt+Ctrl+G for a text search across the entire workspace.
How I do the same in the new 2019.2 vitis?
Hi @davidfi1,
With Vitis, it seems that this shortcut doesn't exist anymore.
Please use Ctrl+H instead and then use the "File Search" tab. It will do the same job.
Abdallah
Hi @davidfi1,
Abdallah
How do I search for "udp.h" - it removes the dot without warning
I need to switch to "File Search" tab....
Culd you please add the old shortcut back?
