invalid command name "open_dsa"
I'm new to reVision Stack on SDx2017.2. Now I try "reVISION Getting Started Guide".
I have zc702, so I use reVision SOM for zc702.
I could build some sample projects (FILEIO - bilateral filter, Harris corner, Optical flow) and run them on zc702.
And I want to see hardware details of SOM, so run follow on VIVADO2017.2 tcl console according to wiki 8.1.
open_dsa ../zc702_trd/hw/zc702_trd.dsa
But console returned follow.
How should I do to use "open_dsa" command ?
Hi Yamashita-san,
Can you check which version of Vivado you are using?
In Vivado 2017.2 I get the following when I try that command:
Vivado% open_dsa
But using the Vivado that installs with SDx tools, I get the following output:
Vivado% open_dsa my.dsa
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '~/SDSoC/2017.2/Vivado/data/ip'.
import_files: Time (s): cpu = 00:00:06 ; elapsed = 00:00:07 . Memory (MB): peak = 1218.969 ; gain = 82.648 ; free physical = 22320 ; free virtual = 205262
INFO: Project created:arty
INFO: [Vivado 12-5431] Succesfully read DSA
So it looks like that command "open_dsa" is only valid in SDx Vivado (which is different than regular Vivado).
Sam
Hi Yamashita-san,
Vivado% open_dsa
Sam
Thank you so much for your early reply!
I used VIVADO 2017.2 that I installed with vivado installer.
Would you tell me how to run VIVADO with SDx?
Hi Yamashita-san,
Once you've installed SDx tools, source the settings script in that installation directory like:
$ source ~/SDSoC/2017.2/settings64.
settings64.csh settings64.sh
either csh or sh depending on your shell type (cshell, bash)
That will source the correct vivado installation (which should be located at: ~/SDSoC/2017.2/Vivado/...
Up until 2017.2 SDx tools shipped a special version of Vivado inside of the SDx installation and were not compatible with any other version of Vivado (for example: 2017.2 SDx is not compatible with 2017.2 Vivado)
Sam
Hi, @skalicky
I have run vivado installed with SDx.
Then, I have verified running "open_dsa" command and opened FPGA design of zc702_trd.
Thank you so much!
