hokim
multiple_cus_asymmetrical execution error
https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/host/multiple_cus_asymmetrical
I built the above example for alveo200 using sdaccel2019.1 and ran it
When I executed it, I met the following error message
./host xclbin/vadd.hw.xilinx_u200_xdma_201830_2.xclbin
Found Platform
Platform Name: Xilinx
INFO: Reading xclbin/vadd.hw.xilinx_u200_xdma_201830_2.xclbin
Loading: 'xclbin/vadd.hw.xilinx_u200_xdma_201830_2.xclbin'
Creating a kernel [vadd:{vadd_1}] for CU(0)
ERROR: kernel 'vadd:{vadd_1}' not found
src/host.cpp:130 Error calling krnls[i] = cl::Kernel(program, krnl_name_full.c_str(), &err), error code is: -46
How can I fix it?
hokim
Sorry for confusing you.
The erro was due to old version o fxrt(201830)
After updating xrt to 201910, there is no problem to run the example
hokim
hongh
Hi, @hokim ,
Thanks for sharing the root cause of the issue.
