ain0102
pragma access_pattern Which pattern is faster?
Hi.
I have to use access_pattern.
#pragma SDS data access_pattern(A:<pattern>)
void function(unsigned char A[10][1000])
    for(int i=0; i<ROW; i++)
        for(int j=0; j<COL; j++)
            if ( ... )
                A[i][j] = 0;
            if ( ... )
                A[i-1][j] = 1;
            if ( ... )
                A[i+1][j] = 1;
My algorithm should use the 'RANDOM' pattern.
Is the 'RANDOM' pattern slower than 'SEQUENTIAL' ?
khareashish_trimble
The RANDOM access pattern would allow a random access to the data however it would require the whole array to be transferred to the hardware accelerator and stored in BRAM. This would increase your BRAM utilization.
On the other hand SEQUENTIAL access does not require memory to store the whole array. The processing of the array elements can be pipelined. The accelerator can start processing new elements while the old ones are still being processed.
I wanna say the RANDOM access pattern could be somewhat slower than SEQUENTIAL but I haven't really experimented with it personally.
khareashish_trimble
