mostafa@sint
problem with stdio.h in the kernel code
Hi All,
I am using the Vitis with the sample vadd project.
I am trying to use printf in the kernel code.  but after stdio.h is added I get following error during the build process:
[v++ 207-812] 'bits/libc-header-start.h' file not found: /usr/include/stdio.h:27:10
Anyone knows how to solve it, or how to use printf in the kernel code?  As I mentioned I am even trying to use the xilinx vadd sample without touching it but I have
not been able to use printf in kernel code at all.
Thanks for your help.
Mostafa
yangc
Hope it helps you https://stackoverflow.com/questions/54082459/fatal-error-bits-libc-header-start-h-no-such-file-or-directory-while-compili/54082790
Try installing below:
sudo apt-get install gcc-multilib
yangc
mostafa@sint
Thanks a lot,
After two times asking it in the forum and no helpful replt finally you saved me.
