recipe for target 'binary_container_1.xclbin' failed make: *** [binary_container_1.xclbin] Error 1
I am currently working with Vitis 2020.1 and trying to program on my Alveo U50 boards with a simple program on Ubuntu 18.04. I think I have successfully installed the Xilinx Runtime, Deployment target platform, development, and Development target platform.
I have successfully passed the Emulation-SW test, but when I tried to make the Emulation-HW test.
I am getting an 2 errors, while building the application in Vitis (using vector addition template)
make:***[binary_container_1.xclbin] Error 1 (resource Hardware).
I am also confused about the procedure to make an application program on Vitis Platform since I cannot find related documentation for developing application on Alveo U50 using Vitis. Do I need to create a xsa file using vivado in order to transfer the program written on Vitis to my Alveo card.
The following is error shown on the console after the Hardware Emulation
[09:03:01] Run vpl: Step create_project: Completed
[09:03:01] Run vpl: Step create_bd: Started
[09:03:58] Run vpl: Step create_bd: Completed
[09:03:58] Run vpl: Step update_bd: Started
[09:04:03] Run vpl: Step update_bd: Completed
[09:04:03] Run vpl: Step generate_target: Started
[09:05:18] Run vpl: Step generate_target: RUNNING...
[09:05:51] Run vpl: Step generate_target: Completed
[09:05:51] Run vpl: Step config_hw_emulation: Started
[09:07:07] Run vpl: Step config_hw_emulation: RUNNING...
[09:07:40] Run vpl: Step config_hw_emulation: Failed
[09:07:45] Run vpl: FINISHED. Run Status: config_hw_emulation ERROR
ERROR: [VPL 60-773] In '/root/workspace/test1/Emulation-HW/binary_container_1.build/link/vivado/vpl/runme.log', caught Tcl error: ./elaborate.sh: line 20: LIBRARY_PATH: unbound variable
ERROR: [VPL 60-2373] In '/root/workspace/test1/Emulation-HW/binary_container_1.build/link/vivado/vpl/runme.log', caught error: ERROR: caught error: ./elaborate.sh: line 20: LIBRARY_PATH: unbound variable
ERROR: [VPL 60-2373] In '/root/workspace/test1/Emulation-HW/binary_container_1.build/link/vivado/vpl/vivado.log', caught error: ERROR: caught error: ./elaborate.sh: line 20: LIBRARY_PATH: unbound variable
ERROR: [VPL 60-1328] Vpl run 'vpl' failed
ERROR: [VPL 60-806] Failed to finish platform linker
INFO: [v++ 60-1442] [09:07:45] Run run_link: Step vpl: Failed
Time (s): cpu = 00:24:43 ; elapsed = 00:05:07 . Memory (MB): peak = 1341.258 ; gain = 0.000 ; free physical = 121266 ; free virtual = 127964
ERROR: [v++ 60-661] v++ link run 'run_link' failed
ERROR: [v++ 60-626] Kernel link failed to complete
ERROR: [v++ 60-703] Failed to finish linking
INFO: [v++ 60-1653] Closing dispatch client.
makefile:92: recipe for target 'binary_container_1.xclbin' failed
09:07:45 Build Finished (took 6m:34s.726ms)
For Ubuntu OS, please run the below command before launching Vitis:
export LIBRARY_PATH=/usr/lib/x86_64-linux-gnu
I retried that using your method but it is still not working, is it because I did not generate a xsa file for u50 using vivado?
For u50, you don't need to generate XSA.
Please confirm that you close the Vitis and relaunch it after setting the environment variable.
Have you solved the problem? I've encountered a similar error and the LIBRARY_PATH didn't work neither.
