saurabhs
report_estimate information
I would like to know more about report_estimate command.
Q1. Does report_estimate output depends on which emulation(flow = cpu or flow = hw) I am doing for my kernel ?
Q2. Will report_estimate also considers the optimizations done by attributes ?
eg:
__attribute__((opencl_unroll_hint))
__attribute__((xcl_array_partition(complete,1)))
__attribute__((xcl_pipeline_loop))
Q3. How accurate are results by report_estimate ?
Please help resolving my queries.
ywu
Please see my answers in line:
[Jim] No. report_estimate output is the same for all flows.
eg:
[Jim] Yes. report_estimate runs HLS first and then gathers results from HLS C-csynthesis and reports them. All optimization attributes and properties are taken into account.
[Jim] It runs HLS C synthesis, so it has the same accuracy as HLS C synthesis report, which is rather accurate based on our regression tests.
Cheers,
Jim
ywu
eg:
Cheers,
Jim
