jack.roundhouse
sdsoc freezes with program fpga
SDSoC application freeze when I select Xilinx / Program FPGA. The menu bar is still responsive but I cannot exit.
A forced termination of the application and a 2nd attempt is successful.
This behaviour is consistent with all my projects / workspaces.
****** Xilinx SDx Development Environment
****** SDx v2018.3 (64-bit)
**** SW Build 2405991 on Thu Dec 6 23:37:15 MST 2018
OS: Ubuntu
OS Version: 4.15.0-46-generic
OS Architecture: amd64
nutang
Hello @jack.roundhouse
Thank you for the reply
Your UBUNTU version is not compatible with SDx.
Software Requirements
The SDSoC™ Development Environment runs on both Linux and Windows operating systems. The supported operating systems are listed below.
  • Windows 7 and 7 SP1 Professional (64-bit)
  • Windows 10 Professional versions 1709 and 1803 (64-bit)
  • Linux Support
    • Red Hat Enterprise Workstation/Server 7.3-7.4 (64-bit)
    • Red Hat Enterprise Workstation 6.7 and 6.8
    • CentOS 7.2
    • Ubuntu Linux 16.04.3 LTS (64-bit)
      • Linux kernel 4.4.0 is supported
      • Ubuntu LTS enablement (also called HWE or Hardware Enablement) is not supported
Please have a look at the link below,
https://www.xilinx.com/html_docs/xilinx2018_2/sdsoc_doc/software-requirements-hdw1504034316054.html
Best Regards,
Nutan
nutang
Hi @jack.roundhouse
What is your full UBUNTU version?
Best Regards,
Nutan
jack.roundhouse
My Ubuntu version is 16.04.6
LSB Version: core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
I should also note that I am using a custom hardware platform. The project is valid and functional, application wise.
nutang
  • Linux Support
    • CentOS 7.2
Best Regards,
Nutan
