sdsoc hw counter usage
I am trying to develop fft application by using sdsoc. I am trying to measure time and to do that, I am using the class which can be utilized by including
"sds_lib.h" and provided below.  I am using the functions and getting count of clock cycles but I do not know the frequency. How am i supposed to know that? Yes, I can measure the time by using soft counters but they are not so accurate. Speed may change even in accordance with heat. Thus, soft counter is not good choice. It would be nice if you can guide. Thanks
#include "sds_lib.h"
#ifndef _PERF_COUNTER_
#define _PERF_COUNTER_
class perf_counter{
private:
uint64_t tot, cnt, calls;
public:
perf_counter() : tot(0), cnt(0), calls(0) {};
   inline void reset() { tot = cnt = calls = 0; };
   inline void start() { cnt = sds_clock_counter(); calls++; };
   inline void stop() { tot += (sds_clock_counter() - cnt); };
   inline uint64_t avg_cpu_cycles() {return (tot / calls); };
#endif
Hi @yhy.xilinx
There is SDS utility perf_counter.
Please refer example below
https://github.com/Xilinx/SDSoC_Examples/blob/master/cpp/getting_started/shift_register/src/main.cpp
Best Regards,
Nutan
I have found sds_clock_frequency() function during checking the library and I am checking the elapsed time with (1000.0)*(1000.0)/sds_clock_frequency())*(double)(m_perf_counter.avg_cpu_cycles() in us. what do you think? is there anyway for me to get more accurate?
Hi @yhy.xilinx
Best Regards,
Nutan
