yanghongsing
sdx 2019.1 failed to do build with system
SDx 2019.1 was installed on Ubuntu 18.04.2 LTS. I loaded the template of Hello_World(HLS C/C++ Kernel) and set platform as xilinx_u250_xdma_201830_2. The project can be built by configuration of both Emulation-SW and Emulation-HW. But the build with System failed with the error message below:
[23:47:17] Run vpl: Step impl: Failed
[23:47:18] Run vpl: FINISHED. Run Status: impl ERROR
===>The following messages were generated while Compiling (synthesis checkpoint) kernel/IP: pfm_dynamic_vadd_1_0 Log file: /home/hyang/workspace/test4/yh_hello_hls/System/vadd/link/vivado/vpl/prj/prj.runs/pfm_dynamic_vadd_1_0_synth_1/runme.log :
INFO: [VPL 17-86] Your Synthesis license expires in 17 day(s)
===>The following messages were generated while Compiling (reconfig module level synthesis checkpoint) dynamic region Log file: /home/hyang/workspace/test4/yh_hello_hls/System/vadd/link/vivado/vpl/prj/prj.runs/my_rm_synth_1/runme.log :
===>The following messages were generated while processing /home/hyang/workspace/test4/yh_hello_hls/System/vadd/link/vivado/vpl/prj/prj.runs/impl_1 :
ERROR: [VPL 17-179] Fork failed: Cannot allocate memory
ERROR: [VPL 60-704] Integration error, problem implementing dynamic region, Design Initialization ERROR, please look at the run log file '/home/hyang/workspace/test4/yh_hello_hls/System/vadd/link/vivado/vpl/prj/prj.runs/impl_1/runme.log' for more information
ERROR: [VPL 60-1328] Vpl run 'vpl' failed
ERROR: [VPL 60-806] Failed to finish platform linker
INFO: [XOCC 60-1442] [23:47:18] Run xocc_link: Step vpl: Failed
Time (s): cpu = 00:00:16 ; elapsed = 00:14:42 . Memory (MB): peak = 636.215 ; gain = 0.000 ; free physical = 7583 ; free virtual = 10257
ERROR: [XOCC 60-661] xocc link run 'xocc_link' failed
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
makefile:87: recipe for target 'vadd.xclbin' failed
make: *** [vadd.xclbin] Error 1
23:47:19 Build Finished (took 15m:29s.95ms)
