spark1001
segmentation fault when using pthread_join()
here is my code :
void* print1(void* data){
printf("1 \n");
pthread_t* t=(pthread_t*)malloc(sizeof(pthread_t));
pthread_create(&t[0],0,print1,NULL);
printf("****** after test create thread******* \n");
pthread_join(t[0],NULL);
printf("****** test pthread lib******* \n");
the result is :
I create the thread successfully,but I can't use pthread_join.
what should I do?
gsmecher
There is no bug in the code you've posted. That means either:
  • There's a problem in the runtime you're using (possible), or
  • There's a bug in the surrounding code you haven't included (seems mosts likely to me).
In order to figure out which is true, please paste a complete example here that exhibits the same segfault. If you don't want to share your code publicly, it's a great idea to trim your example down so it doesn't give away any secrets.
For reference, the following standalone C code is much like yours, and is leak- and error-free. (Don't forget, though, that malloc and pthread_create can return an error code!)
#include <string.h>
#include <pthread.h>
#include <stdlib.h>
#include <stdio.h>
void* print1(void *data) {
        printf("1\n");
        return NULL;
int main(void) {
        pthread_t *t = (pthread_t *)malloc(sizeof(pthread_t));
        pthread_create(t, 0, print1, NULL);
        pthread_join(*t, NULL);
        free(t);
        return 0;
cheers,
Graeme
gsmecher
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
        printf("1\n");
        return NULL;
int main(void) {
        free(t);
        return 0;
cheers,
Graeme
