rpa
setenv.sh location
I've been trying to run the demo file for the Xilinx Vitis Data Compression Zlib library. However before running the demo, it says to run the following files here (https://xilinx.github.io/Vitis_Libraries/data_compression/source/L2/demo.html#zlib-compression-and-decompression ) :
$ source <Vitis_Installed_Path>/installs/lin64/Vitis/2019.2/settings64.sh
$ source <Vitis_Installed_Path>/xbb/xrt/packages/setenv.sh
I was able to find settings64.sh but not the setenv.sh. Where would this file be located? The path provided by the tutorial does not exit within the "Vitis_Installed_Path"
shaunpur
That looks like a typo. Should read
$ source <XRT_Installed_Path>/setup.sh
