wjh12345
../src/host.cpp:200 Error calling cl::Program program(context, devices, bins, NULL, &err), error code is: -44
Found Platform
Platform Name: Xilinx
INFO: Reading mmult.sw_emu.zc706_base.xclbin
Loading: 'mmult.sw_emu.zc706_base.xclbin'
ERROR: dlopen of /home/wjh/Vitis-Tutorials/docs/Pathway3/reference-files/run/.run/23580/sw_emu/device0/binary_0/dltmp is failed. Please check undefined symbols in the kernel
XRT build version: 2.3.1301
Build hash: 192e706aea53163a04c574f9b3fe9ed76b6ca471
Build date: 2019-10-24 20:05:16
Git branch: 2019.2
PID: 23580
UID: 1000
[Wed Dec 18 18:00:35 2019]
HOST: ubuntu
EXE: /home/wjh/Vitis-Tutorials/docs/Pathway3/reference-files/run/host
[XRT] ERROR: Failed to load xclbin.
I am using the official examples and tutorials of the vitis platform. What is wrong
graces
Looks to be the same issue as in previous post. The embedded target platform is not applicable for the Vitis application acceleration tutorial.
https://forums.xilinx.com/t5/Vitis-SDAccel-and-SDSoC/Failed-to-Build-the-hardware-Target-for-system/m-p/1057167#M4176
graces
