wjh12345
the difference between sdsoc and vitis about application acceleration
Hello, I am not familiar with the difference between sdsoc and vitis about application acceleration. Could you help me analyze it? thank you
hongh
Originally Xilinx has SDx, which contains SDSoc and SDAccel.
Vitis merge these flows and SDK, and SDx will not updated.
For new accelerate design, you can use Vitis.
hongh
wjh12345
Hi, thanks for your help!
I have one more question. I found that there are two kinds of application development for hardware acceleration, Embedded Processor Platform and Data Center Platforms. Aside from the fact that embedded targets must run Linux and XRT to support the accelerated development process of Vitis applications, are there any differences between the two platforms
hongh
Please refer to the below links:
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/kme1569523964461.html
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/cmr1566483669657.html
wjh12345
Maybe I didn't make myself clear. I would like to ask you about the hardware accelerated application development, Embedded Processor Platform and Data Center Platforms are there any differences? According to the official document I reviewed, it just says embedded targets must run Linux and XRT to support the accelerated development process of Vitis applications.
hongh
In Embedded Processor Platform, you need to design host code in PS and accelerated code in PL.
In Data Center Platforms, you need to design host code in PC and accelerated kernel running in FPGA, the shell in Platform will help to commnicate with the PC through PCIe.
