bangbang0344
the hardware function hangs when using data copy
My simple hardware function hangs when using data copy.
Here is my code
/**************  hardware function  *************************/
#pragma SDS data mem_attribute(m_iimgBufOffset:NON_CACHEABLE | PHYSICAL_CONTIGUOUS)
#pragma SDS data access_pattern(m_iimgBufOffset:SEQUENTIAL)
#pragma SDS data copy(m_iimgBufOffset[0:152 * 4*4])
#pragma SDS data data_mover(m_iimgBufOffset:AXIDMA_SIMPLE)
int my_function(int* dst)
    int i = 0;
    int sum = dst[30]+dst[40]+dst[0] + dst[20];
    if(sum >1000)
    i = 1;
    return i;
/********************** call  function  *************************/
int* val = (int*)sds_alloc_non_cacheable(sizeof(int)*152*4 * 4);
for(int i = 0; i< 152*4 * 4; i++){
      val[i] = i;
std::cout<<"start my_function"<<std::endl;
my_function(val);
std::cout<<"finish my_function"<<std::endl;
sds_free(val);
skalicky
Hi bangbang,
You have a couple of problems here.
1. Your function is called "my_function" and has an argument called "dst" but your data copy pragma refers to an argument named "m_iimgBufOffset". So that pragma will not get applied when you do a build. There should be a warning about that argument not existing.
2. Please realize that in your data copy pragma you're asking SDSoC to transfer 152 * 4*4 = 2432 elements from the PS (software) to the PL (hardware). SDSoC does this by creating a data mover (DMA) which has an AXI Stream output to your accelerator. Then in your function you only consume elements dst[30]+dst[40]+dst[0] + dst[20]. You must consume all elements in your accelerator that you asked SDSoC to transfer when you use the access_pattern(m_iimgBufOffset:SEQUENTIAL) pragma. If you want a BRAM (which will use more resources), the use RANDOM instead of SEQUENTIAL.
skalicky
Hi bangbang,
