ug1164-sdaccel-platform-development.zip isn't available anymore.
I used the link within P.94 of the ug1164 2018.1 pdf file.
The website says that the reference design file isn't available anymore.
Hi, @xil_tour ,
Now UG1164 is off-line and the related questions are not supported in the forum.
Hi, @xil_tour ,
Ah ?
Any idea why it was removed ?
Is it replaced by something else ?
Hi, @xil_tour ,
Now we recommend customer use Xilinx's platform directly, such as the Alveo cards (U200 and U250).
We don't encourage customer creating platform now.
Ok, thanks for your answer.
But you shouldn't remove any document, this is a bad practice because some may need information buried in those.
For the readers:
although a solution was accepted for my thread, I wasn't the one who accepted it.
It could just be those alveo are just that thing nicely wrapped and sold more expensive.... let's wait for the AI expectations to come back to earth.
Hi, @xil_tour ,
This thread marked as solved just means the off-line documents cannot be provided in the forum.
Sorry for the inconvenience and misunderstanding.
