vitis application built successfully but running on emulator failed
I created Hello world application on revision platform, I build it successfully but after trying to run it on emulator (for both HW and SW) it failed with this error message:
failed to start emulator.
make sure that the application is built properly for configuration 'Emulation-SW' (Emulation-HW) before launching.
XSCT console shows this error message:
ERROR: [Hsi 55-1571] The design file /opt/Xilinx/Vitis/2019.2/platforms/zcu102_dpu/hw/zcu102_dpu.xsa is already opened
how can I solve this issue?
Hi @SaDaR
Please check your active build configuration. Have you built with Emulation-SW configuration?
Best Regards,
Nutan
hi @nutang
yes I built software configuration and then run on sw emulator and I did the same for hardware configuration and hw emulation
I have this problem for both
