vivado hls schedule viewer error
Hi there,
I am having an error with one of my SDAccel projects. Whenever I build the hardware emulation project, I open the vivado HLS for the build and the Schedule Viewer is blank. Has anyone ran into this before? How can I fix it?
The kernel that I had developed was developed for testing and had not input or output to the host. Because it didn't have these, it synthesized out the kernel in hardware emulation. I fixed it by adding an output. I'm surprised there isn't a warning that the entire kernel was synthesized out.
