yhy.xilinx
xfopencv crop application gives SIGSEV
I am trying to compile crop function from the xfopencv. I created new application by selecting it from the examples. It is built fine. However, it gives SIGSEV on card. Why would be the reason? I have changed nothing, just built and sent boot.bin image.ub and crop.elf to the sd card with the relevant libraries.
Thanks for any kind of a help.
Tags (3)
yhy.xilinx
i guess it was using some libraries that it shouldn't, i cleared the library file and sent the libraries from the sysroot and it worked.
yhy.xilinx
