.xo packaging
Hi, Based on ug1393 chapter "RTL Kernels" A control interface including a start, done and idle is mandatory for kernel to be packaged properly.
1) Assuming the Kernel uses only AXI-Stream interface. what is the purpose  of such a control port? The whole purpose of AXI-stream is having a continues stream enabled by TREADY. No need for start or done.
What should I do with these ports?
2) Are these ports actually the S-AXI4-LITE ports? If so, how are these ports used with AXI-4-LITE interface?
The RTL Kernel wizard supports the ap_ctrl_none protocol and does not require the control signals. You can use this for streaming kernels as described here:
https://www.xilinx.com/html_docs/xilinx2020_1/vitis_doc/streamingconnections.html#uug1556136182736
"Streaming" data from host to FPGA is only supported with QDMA platforms which are only available for a limited set of Xilinx boards and the platforms are not publicly distributed by Xilinx. With the standard XDMA platforms, only memory mapped and AXI lite interfaces are supported. Moreover, I am not sure if RTL kernels are supported with QDMA platforms. You should probably contact your Xilinx FAE for information.
The host in my case is the AIE, which does support streaming interface.
