取消
显示结果
搜索替代
您的意思是:
394 次查看
注册日期: ‎11-11-2018
如何在安装好的vitis上添加硬件平台
我在ubuntu16.04上安装好了vitis,但是当时好多devices of custom platform都没有勾上。现在工程报错:
/tools/Xilinx/Vivado/2019.2/bin/vivado -mode batch -source scripts/gen_xo.tcl -tclargs ./_x.hw_emu.xilinx_u200_xdma_201830_2/krnl.xo krnl hw_emu xilinx_u200_xdma_201830_2 xilinx_u200_xdma_201830_2
我现在要怎么更新,或者怎么安装啊?
0 项奖励
4 条回复4
340 次查看
注册日期: ‎07-17-2008
回复: 如何在安装好的vitis上添加硬件平台
如果你是要安装U200 platform,请按照网页所示步骤1,2,3下载并安装。
https://www.xilinx.com/products/boards-and-kits/alveo/u200.html#gettingStarted
339 次查看
注册日期: ‎02-28-2019
Hi @lxjie ,
如果想用Alveo办卡开发,需要额外安装xrt,deployment等,参考链接https://www.xilinx.com/products/boards-and-kits/alveo/u200.html#gettingStarted
311 次查看
注册日期: ‎11-11-2018
我安装了Deployment-Target-Platform,但是并没有成功:
(base) root@***:~/xilinx/Deployment-Target-Platform# dpkg -i ./xilinx-u200-xdma-201830.2-2580015_16.04.deb
(Reading database ... 229979 files and directories currently installed.)
Preparing to unpack .../xilinx-u200-xdma-201830.2-2580015_16.04.deb ...
Unpacking xilinx-u200-xdma (201830.2-2580015) over (201830.2-2580015) ...
Setting up xilinx-u200-xdma (201830.2-2580015) ...
DSA package installed successfully.
Please flash card manually by running below command:
sudo /opt/xilinx/xrt/bin/xbutil flash -a xilinx_u200_xdma_201830_2 -t 1561465320
(base) root@***:~/xilinx/Deployment-Target-Platform# /opt/xilinx/xrt/bin/xbutil flash -a xilinx_u200_xdma_201830_2 -t 1561465320
WARNING: The xbutil sub-command flash has been deprecated. Please use the xbmgmt utility with flash sub-command for equivalent functionality.
Card not found!
(base) root@***:~/xilinx/Deployment-Target-Platform# /opt/xilinx/xrt/bin/xbutil flash scanWARNING: The xbutil sub-command flash has been deprecated. Please use the xbmgmt utility with flash sub-command for equivalent functionality.
No card is found!
可否再帮忙看一下
0 项奖励
306 次查看
注册日期: ‎07-17-2008
加速卡有正确安装吗?可以参考UG1301:
https://www.xilinx.com/support/documentation/boards_and_kits/accelerator-cards/2019_1/ug1301-getting-started-guide-alveo-accelerator-cards.pdf
Ch.3 Card Installation Procedures
0 项奖励
