取消
显示结果
搜索替代
您的意思是:
421 次查看
注册日期: ‎06-18-2019
新装软件打不开求助怎么解决
出现这个问题:An error has occurred. See the log file
/home/wangshunji/新建文件/.metadata/.log
日志文件
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:450)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:156)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:99)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:141)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
... 21 more
求助怎么解决
0 项奖励
2 条回复2
418 次查看
注册日期: ‎06-18-2019
回复: 新装软件打不开求助怎么解决
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-06-18 14:26:13.014
!MESSAGE FrameworkEvent ERROR
!STACK 0
... 21 more
日志文件更新
0 项奖励
327 次查看
注册日期: ‎11-05-2010
回复: 新装软件打不开求助怎么解决
Hi, @daiyu ,
你安装的是什么版本的软件?用的操作系统是什么?
0 项奖励
