Visitor loldaa
2017.4 Sdaccel Ubuntu16.03 XOCC Options --kernel_frequency problem
Hi, everyone
I want to lower my kernel frequency below 300MHZ, since some time if your kernel run too fast they will give you a integration error like following
===>The following messages were generated while Compiling (bitstream) opencl binary: kernel Log file: .... :
ERROR: [vpl-1] design did not meet timing, auto frequency scaling failed because an unscalable system clock did not meet the target frequency. Please try specifying a clock frequency lower than 500 using the '--kernel_frequency' switch for the next compilation
ERROR: [vpl 60-704] Integration error, problem implementing dynamic region, route_design ERROR
ERROR: [vpl 60-806] Fail to finish platform linker
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
Then I edit the xocc options by parameter "--kernel_frequency  200", but the hls report did not change anything
Is it a bug, or I do something wrong?
By the way, I can change the uncertainty by edit xocc option
"--xp prop:solution.kernel_compiler_margin=<Frequency Percentage>"
This really success.
Re: 2017.4 Sdaccel Ubuntu16.03 XOCC Options --kernel_frequency problem
The exact reason is in the accepted solution of the new thread:
https://forums.xilinx.com/t5/SDAccel/sdx2017-4-XOCC-kernel-compiler-cannot-set-kernel-frequency/td-p/894185
Are you using RTL kernel? If so please try with:
xocc --kernel_frequency "0:200"
It will not affect the HLS result but it should be able to be reflected in the final Vivado timing result.
Visitor loldaa
Thanks seans and yunl.
Yes,  I found it in the log file says it change the clock frequency at last time. I miss the message in the console.
The command of  "--xp prop:solution.kernel_compiler_margincan" can reflect in the hls report, so I think "kernel_frequency" will do the same thing.
Clearly, I misunderstanding this.
Visitor yunzhehi
just confused, does the "--kernel_frequency" not working in XOCC kernel compiler or it worked but not show in the log?
