Build error with SDSoC 2016.4 new installation
I am unable to build projects that were working without any problem on the 2016.3 version. What's the problem?
C:\Xilinx\Projects\HVDC_MMC\Debug>exit /b 0
INFO: [SDSoC 0-0] Compiling C:/Xilinx/Projects/HVDC_MMC/src/main.cpp
arm-none-eabi-g++.exe: error: CreateProcess: No such file or directory
ERROR: [SDSoC 0-0] Exiting sds++ : Error when calling 'arm-none-eabi-g++ -c -I../src -Wall -O0 -g -fmessage-length=0 -MMD -MP -D __SDSCC__ -MTC:/Xilinx/Projects/HVDC_MMC/Debug/src/main.o -MFC:/Xilinx/Projects/HVDC_MMC/Debug/src/main.d -MTC:/Xilinx/Projects/HVDC_MMC/Debug/src/main.o -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard    -I C:/Xilinx/SDx/2016.4/aarch32-none/include  -I C:/Xilinx/SDx/2016.4/Vivado_HLS/include C:/Xilinx/Projects/HVDC_MMC/src/main.cpp -o src/main.o'
sds++ log file saved as C:/Xilinx/Projects/HVDC_MMC/Debug/_sds/reports/sds_main.log
ERROR: [SDSoC 0-0] Build failed
make: *** [src/main.o] Erreur 1
The environment variable PATH has the right address to the GCC compiler (C:\Program Files (x86)\EGCS\bin). I don't know what's going on.
Cerilet
Re: Build error with SDSoC 2016.4 new installation
Ok, I have found the problem.
It resulted from a program called EGCS (Experimental/Enhanced GNU Compiler System). I installed it as a prerequisite for PSCAD (Power Systems CAD) along with a FORTRAN Compiler.
Just remove it, restart the computer and you'll be fine ;-)
Cerilet
Hi cerilet,
Can you attach the file:
Sam
Cerilet
