CHaiDNN demo problem
Demo output text file are all zeros. what is the problem?
Re: CHaiDNN demo problem
What net did you use ?
Can you upload your output text file here ?
Hey, thanks for your reply.
I had tried several network. VGG, googlenet. they are all not working.
Do you have any hint? There is no error reported while it was running. But output.txt is zeros.
Lily
solved.
Hey, how did you solve this? Could you please elaborate on the issue and let us know how you solved it?
after building the software i am not getting any output
