I have a doubt about the CHaiDNN, is it part of the reVISION stack ?
Also, I have seen this page : https://www.xilinx.com/applications/megatrends/machine-learning.html and now I am confused.
Is there a link with reVISION or is it something completely different ?
thanks in advance,
ML
Re: CHaiDNN
The communication about the machine learning toolkit provided by Xilinx is very confusing.
You can consider CHaiDNN as an open-source project which has no real link with the reVISION stack.
Best regards.
Re: CHaiDNN
Best regards.
Re: CHaiDNN
Thank you Neutrinoxy
