CMA reserved addresses when creating a new SDSoC platform
I have created a SDSoC platform for Trenz TE0803 StarterKit but when I tried to execute the SDx application inside my board this gets stuck. This is what I see:
root@te0803-3eg-tebf0808-zynqmp:/mnt# ./Matrix.elf
[   31.166537] xlnk_eng_probe ...
[   31.169533] uio name xilinx-xlnk-eng.0
[   31.173273] xilinx-xlnk-eng xilinx-xlnk-eng.0: physical base : 0xa0000000
[   31.180019] xilinx-xlnk-eng xilinx-xlnk-eng.0: register range : 0x10000
[   31.186617] xilinx-xlnk-eng xilinx-xlnk-eng.0: base remapped to: 0xffffff800a4a0000
[   31.194390] xilinx-xlnk-eng xilinx-xlnk-eng.0: xilinx-xlnk-eng uio registered
Briefly below I am going to explain which steps I have followed until having this error:
First I have created the platform in Vivado. This is how it looks like:
Second I have defined the platform properties
set_property PFM_NAME "xilinx.com:sdx:SK0803_zusys_SDSoC:1.0" [get_files ./SK0803_zusys_SDSoC.srcs/sources_1/bd/zusys/zusys.bd]
set_property PFM.CLOCK { \
 clk_out1 {id "0" is_default "true" proc_sys_reset \
"proc_sys_reset_2" } \
clk_out2 {id "1" is_default "false" proc_sys_reset \
 clk_out3 {id "2" is_default "false" proc_sys_reset \
clk_out4 {id "3" is_default "false" proc_sys_reset \
 } [get_bd_cells /clk_wiz_0]
set_property PFM.AXI_PORT { \
 M_AXI_HPM0_FPD {memport "M_AXI_GP"} \
 M_AXI_HPM1_FPD {memport "M_AXI_GP"} \
 M_AXI_HPM0_LPD {memport "M_AXI_GP"} \
 S_AXI_HPC0_FPD {memport "S_AXI_HPC" sptag "HPC0"} \
 S_AXI_HPC1_FPD {memport "S_AXI_HPC" sptag "HPC1"} \
 S_AXI_HP0_FPD {memport "S_AXI_HP" sptag "HP0"} \
 S_AXI_HP1_FPD {memport "S_AXI_HP" sptag "HP1"} \
 S_AXI_HP2_FPD {memport "S_AXI_HP" sptag "HP2"} \
 S_AXI_HP3_FPD {memport "S_AXI_HP" sptag "HP3"} \
} [get_bd_cells /zynq_ultra_ps_e_0]
set intVar []
for {set i 1} {$i < 8} {incr i} {
 lappend intVar In$i {}
set_property PFM.IRQ $intVar [get_bd_cells /xlconcat_0]
Generate the Device Support Archive
set_property dsa.name SK0803_zusys_SDSoC [current_project]
write_dsa -file SK0803_zusys_SDSoC.dsa -include_bit
validate_dsa SK0803_zusys_SDSoC.dsa -verbose
Software Platform Data Creation with Petalinux.
1.- Create Proyect
2.- Configure Kernel
Set CMA size to be larger, for SDS-alloc buffers:
  • for Zynq MPSoC: Device Drivers→ Generic Driver Options → Size in Mega Bytes(1024)
  • for Zynq-7000: Device Drivers→ Generic Driver Options → Size in Mega Bytes(256) Enable staging drivers:
  • Device Drivers → Staging drivers (ON) Enable APF management driver:
  • Device Drivers → Staging drivers → Xilinx APF Accelerator driver (ON) Enable APF DMA driver:
  • Device Drivers → Staging drivers → Xilinx APF Accelerator driver → Xilinx APF DMA engines support (ON)
Note: For Zynq MPSoC, you must turn off CPU idle and frequency scaling. To do so, mark the following orঞonsĹ CPU Power Management->CPU idle->CPU idle PM support (OFF) CPU Power Management->CPU Frequency scaling->CPU Frequency scaling (OFF)
3.- Configure rootfs
Add stdc++ libs: * Filesystem Packages → misc → gcc-runtime → libstdc++ (ON)
4.- Change device-tree
 xlnk {
 compatible = "xlnx,xlnk-1.0";
5.- Build petalinux image
To Create an SDSoC Platform Project, I have launched SDx and
1.- Create new SDx Project -> Platform Project.
2.- Import Device Support Archiv (DSA) file.
3.- Define the Software Platform defining system configuration and processor domain.
4.- Finally Generate Platform and Add to Repository
When the Platform is finished I have created a new Project  with the Direct connect sample.
The trick comes here:
If I use the BOOT.bin generated by SDx that has the accelerated bitstream and petalinux provided image.ub (Image, rootfs and device-tree) everything is working perfectly and I see this in the console.
root@sdsoc:/mnt# ./Matrix.elf
[   37.639151] xlnk_eng_probe ...
[   37.644393] uio name xilinx-xlnk-eng.0
[   37.650311] xilinx-xlnk-eng xilinx-xlnk-eng.0: physical base : 0xa0000000
[   37.659289] xilinx-xlnk-eng xilinx-xlnk-eng.0: register range : 0x10000
[   37.668101] xilinx-xlnk-eng xilinx-xlnk-eng.0: base remapped to: 0xffffff800a450000
[   37.678090] xilinx-xlnk-eng xilinx-xlnk-eng.0: xilinx-xlnk-eng uio registered
Number of CPU cycles running application in hardware: 3009590
TEST[   37.707350] xilinx-xlnk-eng xilinx-xlnk-eng.0: xilinx-xlnk-eng uio unregistered
 PASSED.
but if I tried to separate this image.ub in different parts (Image, rootfs and device-tree) and create a persistent rootfs inside my SDCard inside a new partition I get stuck in the above message
At first I thought that I was getting stuck because fpga was not well programmed but if image.ub works okey I do not think this is problem.
To boot with persistent rootfs I have created the nex uEnv.txt file
kernel_image=Image
devicetree_image=te0803-3eg-tebf0808-zynqmp.dtb
dtb=system.dtb
bootargs=console=ttyPS0,115200 root=/dev/mmcblk1p2 rw rootwait earlyprintk
uenvcmd=echo Copying Linux from SD to RAM... && load mmc $sdbootdev:$partid $fdt_addr ${devicetree_image} && load mmc $sdbootdev:$partid $kernel_addr ${kernel_image} && booti $kernel_addr - $fdt_addr
where kernel_addr=0x80000 and fdt_addr=4000000 and it can be boot with
setenv sdbootdev 1
run uenvboot
In the other hand when I boot with image.ub I am using
mmcinfo && fatload mmc 1 ${netstart} ${kernel_img};bootm ${netstart}
setenv netstart 0x10000000
setenv kernel_img image.ub
So can this error be due to how I store kernel, rootfs and device-tree files inside the memory?
From kernel logs I see that when I boot with image.ub.
cma: Reserved 1024 MiB at 0x000000003bc00000
and from persistent
[    0.000000] cma: Reserved 1024 MiB at 0x0000000040000000
So cma reserves memory in different locations....
Someone know how to solve this to have persistent rootfs?
Thank you very much,
Jorge
Re: CMA reserved addresses when creating a new SDSoC platform
I have solved the issue changing this line in the uEnv.txt
with this new one:
bootargs= earlycon clk_ignore_unused root=/dev/mmcblk1p2
Thanks!
Jorge
with this new one:
Thanks!
Jorge
