Participant jameshko
Compile error for host code on SDAccel 2017.4 Examples Github
Hello all,
I have successfully run hw emulation for an example from the SDAccel Github 2017.4 branch https://github.com/Xilinx/SDAccel_Examples/tree/2017.4
Next, I am trying to compile for ppc64le ( I was able to compile for hw if it is x86 as I am running it from an X86 machine ). However, my runtime is on a ppc64le machine, so I tried to use the ARCH=POWER. I m faced with compile error that suggest g++ version incompatibility.
Here are my command line:
export XCL_EMULATION_MODE=false
make ARCH=POWER all &> error.log
I have attached a more detailed error.log.
snippets of the error.log is as below:
/opt/Xilinx/SDx/2017.4/gnu/ppc64le/4.9.3/lnx64/bin/powerpc64le-linux-gnu-g++ -Wall -O0 -g -std=c++14 -I./src/ -I../../..//libs/xcl2 -I/opt/Xilinx/SDx/2017.4/runtime/include/1_2 ./src/host.cpp ../../..//libs/xcl2/xcl2.cpp -o host -L/opt/Xilinx/SDx/2017.4/runtime/lib/ppc64le -lxilinxopencl -llmx6.0
In file included from /opt/Xilinx/SDx/2017.4/gnu/ppc64le/4.9.3/lnx64/powerpc64le-linux-gnu/include/c++/4.9.3/bits/move.h:57:0,
from /opt/Xilinx/SDx/2017.4/gnu/ppc64le/4.9.3/lnx64/powerpc64le-linux-gnu/include/c++/4.9.3/bits/stl_pair.h:59,
from /opt/Xilinx/SDx/2017.4/gnu/ppc64le/4.9.3/lnx64/powerpc64le-linux-gnu/include/c++/4.9.3/utility:70,
from /opt/Xilinx/SDx/2017.4/runtime/include/1_2/CL/cl2.hpp:547,
from ../../..//libs/xcl2/xcl2.hpp:38,
from ./src/host.cpp:29:
/opt/Xilinx/SDx/2017.4/gnu/ppc64le/4.9.3/lnx64/powerpc64le-linux-gnu/include/c++/4.9.3/type_traits:87:39: error: ‘__vector(4) __bool int’ is not a valid type for a template non-type parameter
typedef integral_constant<bool, true> true_type;
Are there any other compiler that I can use to cross compile the host code for ppc64le?
Re: Compile error for host code on SDAccel 2017.4 Examples Github
Hi @jameshko
I don't think we support PowerPC and you may find in 18.2 UGs that only x86 host is mentioned. I am not sure why the 'ARCH' option is kept in the Github examples but they are not supported or tested on PowerPC machines.
Hi @jameshko
