Compiling RTL Kernel in debug mode
How do I compile RTL kernels in debug mode. I did create the sdaccel.ini file where my hostcode resides but when I launch my hw emulation it is giving me below message
"WARNING: [SDx-EM 07] None of the kernels is compiled in debug mode. Compile kernels in debug mode to launch waveform"
How do I include my sdaccel.ini file in make flow or does it get picked automatically?
Re: Compiling RTL Kernel in debug mode
You can open Sdx GUI and run an example design. The project manager creates the sdaccel.ini file automatically based on
your run configuration and saves it next to the host executable.
You can modify this sdaccel.ini as you want.
For command line users, the runtime initialization file needs to be created manually. The file must be named sdaccel.ini and saved in the same directory as the host executable.
How do I create runtime initialization file?Can you point me to sample runtime initialization file?
