Compute Unit Limit
Hi, all
Currently, I am doing implementations using Xilinx OpenCL.
I have a problem that the CU exceeds the maximum CU number (10) allowed on the platform.
My design is not data-level parallelism, thus cannot use the ND range model, I think.
I also know there are only 10 master/slave interfaces allowed to connect to AXI. But I actually connect the kernels using pipes and only two kernels have global memory access.
Any idea about that?
Besides, does Xilinx OpenCL support pipe array? It should be useful when we have many pipes...
BR
Re: Compute Unit Limit
Hi @hebingsheng
Another option is the merge multiple kernel functionalities into single kernel and use dataflow to run them concurrently.
You  can refer below example for this case:
https://github.com/Xilinx/SDAccel_Examples/blob/master/getting_started/dataflow/dataflow_func_ocl/src/adder.cl
In above examples three sub-functions run concurrently and these functions are sharing data using stream interface. Stream depth can be specified using xocc level option as below (see Makefile in same example)
--xp param:compiler.xclDataflowFifoDepth=32
-Heera
One more thing, it gives:  Max number of compute units in OpenCL binary exceeded.
Actually, no matter whether the kernel uses the global memory or not, it is still a CU, right?
Literally, I can imagine there are 10 kernels allowed at most... for Xilinx OpenCL.....  right?
Hi, @hebingsheng ,
1. Please refer to the below post:
https://forums.xilinx.com/t5/SDAccel/10-compute-unit-limit/m-p/693901#M135
2. Currently "Pipe array" is not supported.
I have seen that discussion, but I think it does not help.
I have 16 asynchronous kernels. I cannot find a way to integrate them in fewer kernels. any idea about that?
Hi @hongh
Thanks for your reply.
Hi, @hebingsheng ,
You can try to split some of the CUs into the different SLRs.
Hi @hebingsheng
-Heera
FYI, I have 16 kernels and 16 queues running (as well as 16 threads running on the ARMs). The each kernel has 3 global arguments. This is in 18.2
How many global arguments in the 2 kernels that have them?  At the end of my compile the compiler adds the axi_interconnects.
In trying to think of why mine works but yours does not I have multiple queues one for each kernel. Each kernel only has 3 global varaibles. I have just compiled 24 kernels but I can't get this to run.
I use xocc to compile from the command line and that might mak a difference.
Poking around I found this... There might be a setting in a .ini file you can change or just put this on the comand line.
param:compiler.​maxComputeUnitsType: Int
Default Value: -1
Maximum compute units allowed in the system. Any positive value will overwrite the numComputeUnits setting in the hardware platform (.dsa). The default value of -1 preserves the setting in the DSA.
