Visitor yushans
Convert SDAccel Device Hardware Transaction View from wdb to txt?
I am using SDAccel 2017.4 and have generated the Device Hardware Transaction View with the detailed kernel trace. It's format is in wdb and wcfg. I am able to view it in SDx. Is there a way to convert the Device Hardware Transaction View into another format like txt so that I could analyze it using matlab/python?
Thank you!
Yushan
Re: Convert SDAccel Device Hardware Transaction View from wdb to txt?
Xilinx doesn't provide a tool to convert wbd file csv file.
Please try
 sdx_analyze trace -i ***.csv -f json
brucey
Visitor yushans
Thank you for the suggestion!
I tried
sdx_analyze trace -i test.csv -f json
but got the error
ERROR: Invalid filename: test.csv
I added an -g flag to the xocc command and added launch_waveform=gui to the sdaacel.ini file. I got an ***.wcfg and ***.wdb as output. The output is like the Device hardware transaction view in Page 60 and Page 61 of this document (https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug1207-sdaccel-optimization-guide.pdf). Is there a way to convert ***.wcfg and ***.wdb to a csv file?
Thank you!
Yushan
Visitor yushans
I guess this command converts ***.csv to ***.wdb?
Is there a command which converts ***.wdb to ***.csv?
Thanks!
Yushan
Visitor yushans
Thank you for the information. Page #35 of this tutorial converts the csv files of the profile summary and timeline trace to files SDx can read.
Is there a way to convert the Device Hardware Transaction View file, which is a wdb file SDx can read, to a csv file?
Thanks!
Yushan
