Creating Vitis platform for petalinux
When creating a platform in Vitis and selecting petalinux as the OS, there is a warning about some details need to be specified. Fine. But when the project is open, I'm not sure which are the directories I should point to. I built a petalinux project that boots but, some things don't exist, like the Bif file or the sysroot directory.
What am I missing?
Re: Creating Vitis platform for petalinux
 @archangel-lightworks,
You should generate your sysroot file from your PetaLinux project using the following commands:
  petalinux-build --sdk
  petalinux-package --sysroot
Further details could be found in the "SDK Generation (Target Sysroot Generation)" section of the UG1144.
Best regards,
Abdallah
will you please explain whole process or refer a document for creating a platform in vitis for Petalinx 2019.2.
You need to create the sysroots:
  • mkdir -p images/linux/sysroot_dir
  • petalinux-build --sdk
  • petalinux-package --sysroot -d sysroot_dir
Copy the following file to a "boot" folder:
  • fsbl.elf
  • uboot.elf
  • bl31.elf
  • bitstream
Create the BIF:
the_ROM_image:
  [fsbl_config] a53_x64
  [bootloader] <zcu102_base/boot/fsbl.elf>
  [pmufw_image] <zcu102_base/boot/pmufw.elf>
  [destination_device=pl] <bitstream>
  [destination_cpu=a53-0, exception_level=el-3, trustzone] <zcu102_base/boot/bl31.elf>
  [destination_cpu=a53-0, exception_level=el-2] <zcu102_base/boot/u-boot.elf>
Copy the image.ub to a53/xrt/image
Then launch Vitis, and create platform project:
Then build. This will take a while as it is copying the sysroots to your newly created platform
