Observer remy561
Demosaic kernel: getting II to 1
Hi all,
I'm currently implementing a Demosaic kernel by moving a matrix along the input image. For caching the pixels, I used the prefetching method used in the sobel and convolution examples. However, the compiler seems to be unable to get II lower than 2 due to the two accesses to loadbuffer. My code is as shown below, executing what occurs in the Sobel example on line 130 & 134.
loop_buf_row: for( int r = 0; r < MATRIX_HEIGHT - 1; r++ ) {
	// Add values from loadbuffer to end of pixelbuffer
	loop_buf_loadbuf: for( int c = 0; c < BURST_SIZE; c++ ) {
		pixelbuffer[r][(PIXELBUF_WIDTH - BURST_SIZE) + c] = loadbuffer[r][c + index];
	// Write values from start of next line to buffer
	loop_buf_store: for( int c = 0; c < BURST_SIZE; c++ ) {
		loadbuffer[r][c + index] = pixelbuffer[r + 1][c];
Additionally, my buffers are partitioned similarly as well to lines 93 and 97 in the example:
// Buffer used to process the pixels
uchar pixelbuffer[MATRIX_HEIGHT][PIXELBUF_WIDTH]
	__attribute__((xcl_array_partition(complete,1)))
	__attribute__((xcl_array_partition(complete,2)))
// Buffer used to store loaded pixels
uchar loadbuffer[MATRIX_HEIGHT - 1][LOADBUF_WIDTH]
	__attribute__((xcl_array_partition(cyclic,BURST_SIZE,2)))
So, can anybody help me with what I can do to get my II to 1?
My idea so far is to double the cyclic partitioning factor, add an additional burst-sized buffer, and write to loadbuffer on the next cycle. However, as this is not needed in the example, I'd like to know why the approach of the example does not work on my end.
Thanks for your help in advance!
Kind regards,
Remy
Observer remy561
Re: Demosaic kernel: getting II to 1
Hi Brucey,
Thanks for your response.
I have solved the issue by copying the Sobel example one to one, and gradually replacing the Sobel parts with my demosaicing function, making sure II remains 1 with every change I made. :)
Likely some unlucky addressing in my old code caused the dependency issue, however as I'm close to a deadline I do not have the time to analyze my code to find where the exact issue is located.
Thanks for your help though!
Kind regards,
Remy
Is "index" used here multiple of BURST_SIZE? It should be.
 And what's the warning message about II not achieved?
brucey
Observer remy561
Hi Brucey,
Kind regards,
Remy
