Observer skotti
Do reads into local arrays inside another loop always produce read requests?
Hello!
I have such a kernel where I decided to copy array to local memory because the next cycle will iterate through it.
However it produces long read requests which are not produced for example when I read array B int very beginning of the function. What is the reason for this?
__kernel void kernel0(__global double *A, __global double *B, __global double *tmp, double alpha)
    int b0 = get_group_id(0), b1 = get_group_id(1);
    int t0 = get_local_id(0), t1 = get_local_id(1);
    local double local_A[210] __attribute__((xcl_array_partition(complete,1)));
    local double local_B[39900] __attribute__((xcl_array_partition(block,210,1)));
    __attribute__((xcl_pipeline_loop))
    for (int c0 = 0; c0 < 39900; c0++) {
    	local_B[c0] = B[c0];
    for (int c0 = 0; c0 <= 179; c0 += 1)
      for (int c1 = 0; c1 <= 189; c1 += 1) {
    	double result = 0.0;
    	for (int c3 = 0; c3 <= 209; c3 += 1) {
    		local_A[c3] = A[c0*210+c3];
        for (int c2 = 0; c2 <= 209; c2 += 1) {
          result += (((alpha) * local_A[c2]) * local_B[c2 * 190 + c1]);
        tmp[c0 * 190 + c1] = result;
        barrier(CLK_LOCAL_MEM_FENCE | CLK_GLOBAL_MEM_FENCE);
Re: Do reads into local arrays inside another loop always produce read requests?
Hi @skotti,
I am not quite clear about your query. Are you saying that the local_B buffer read is working fine but the local_A buffer read produces long read request?
We can support local buffer copy inside a nested loop. For example, here is an example: https://github.com/Xilinx/SDAccel_Examples/blob/master/getting_started/kernel_to_gmem/burst_rw_ocl/src/vadd.cl
Could you elaborate more about 'long read request'?
Hi @skotti,
Observer skotti
I mean that when reading to local array A I have a long readreq command up to 50 cycles or so before reading each values from ddr memory.
Can I somehow get read of this latency?
The access to DDR memory will cause latency overhead and I think 50 cycles is not quite huge. The latency depends on memory access manner and controller settings etc. Instead of reducing that latency, I think the better way would be hide the the latency, such as using burst transfer or on-chip pipe etc. You may refer to UG1207 or the github examples for more details.
