ERROR Creating the ZC702 Platform Tutorial
I am trying to run the "Creating ZC702 Platform" tutorial from ug1146, Appendix C. I followed the described steps. After I clicked Generate button I got the following error:
ERROR: [SdsPfm 83-5451] Exiting sdspfm : Error when calling 'vivado -mode batch -notrace -source archive_project.tcl
SDSoC Version: 2017.2
OS: Windows
Do you know how to resolve this issue?
Thank you,
Bogdan
Tags (3)
Re: ERROR Creating the ZC702 Platform Tutorial
I found the problem:
According to this post Vivado does not work correctly if Windows 10 had updated to version 1709, generating the "R6025 - pure virtual function call" error. Because SDSoC uses Vivado, the mentioned error propagates in the platform generation process. To solve the problem I used this Xilinx's Answer with the mention that I made the modification in C:\Xilinx\SDx\2017.2\bin\unwrapped\win64.o\ and C:\Xilinx\Vivado\2017.2\unwrapped\win64.o\.
Also, I removed the C:\Users\<user_id>\AppData\Roaming\Xilinx directory according to this post.
