ERROR: [XOCC 60-398] sdx_link failed - OpenCL kernel
I am using sdx 2018.2. I am trying to compile a very simple saxpy kernel for testing compilation but I cannot get the bitstream (see the second compilation step).
I am following this documentation: https://www.xilinx.com/html_docs/xilinx2018_2_xdf/sdaccel_doc/compiling-your-opencl-kernel-using-xilinx-opencl-compiler-(xocc)-wrj1504034328013.html
First compilation from OpenCL to object file (.xo) with no errors:
$ xocc -c --platform xilinx_kcu1500_dynamic_5_0 mykernel.cl -o mykernel.xo
****** xocc v2018.2 (64-bit)
  **** SW Build 2258646 on Thu Jun 14 20:02:38 MDT 2018
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
Attempting to get a license: ap_opencl
Feature available: ap_opencl
INFO: [XOCC 60-585] Compiling for hardware target
Running SDx Rule Check Server on port:45291
INFO: [XOCC 60-895]   Target platform: /localhome/opt/Xilinx/SDx/2018.2/platforms/xilinx_kcu1500_dynamic_5_0/xilinx_kcu1500_dynamic_5_0.xpfm
INFO: [XOCC 60-423]   Target device: xilinx_kcu1500_dynamic_5_0
INFO: [XOCC 60-242] Creating kernel: 'saxpy'
===>The following messages were generated while  performing high-level synthesis for kernel: saxpy Log file:/home/juan/fpga-opencl-examples/c++/saxpy/_x/mykernel/saxpy/vivado_hls.log :
INFO: [XOCC 204-61] Option 'relax_ii_for_timing' is enabled, will increase II to preserve clock frequency constraints.
INFO: [XOCC 204-61] Pipelining loop 'XCL_WG_DIM_X'.
INFO: [XOCC 204-61] Pipelining result : Target II = 1, Final II = 2, Depth = 155.
INFO: [XOCC 60-594] Finished kernel compilation
INFO: [XOCC 60-244] Generating system estimate report...
INFO: [XOCC 60-1092] Generated system estimate report: /home/juan/fpga-opencl-examples/c++/saxpy/_x/reports/mykernel/system_estimate_mykernel.xtxt
WARNING: [XOCC 17-1525] IP definition with the same IP name already exists in XO container. Will overwrite the existing IP definition.
INFO: [XOCC 60-586] Created mykernel.xo
INFO: [XOCC 60-791] Total elapsed time: 0h 0m 20s
However, during the linking process and bitstream generation:
$ xocc -l --platform xilinx_kcu1500_dynamic_5_0 mykernel.xo -o mykernel.xclbin
INFO: [XOCC 60-629] Linking for hardware target
Running SDx Rule Check Server on port:33625
INFO: [XOCC 60-825] xocc command line options for sdx_link are --xo mykernel.xo
using /localhome/opt/Xilinx/SDx/2018.2/platforms/xilinx_kcu1500_dynamic_5_0/xilinx_kcu1500_dynamic_5_0.xpfm
extracting xo v3 file /home/juan/fpga-opencl-examples/c++/saxpy/mykernel.xo
couldn't compile regular expression pattern: quantifier operand invalid
    while executing
"regsub $source_dir $source_file $target_dir target_file"
    (procedure "::sdsoc::file::copyDirectoryIfDifferent" line 10)
    invoked from within
"::sdsoc::file::copyDirectoryIfDifferent $ip_root_dir $ip_dir"
    (body of "dict with")
    invoked from within
"dict with kdata {
      # an IP may be referenced by more than one kernel, but there is only
      # one copy of each IP
      set ip_base [file tail ..."
    (procedure "sdsoc::link::extract_xo_v3_file" line 103)
    invoked from within
"sdsoc::link::extract_xo_v3_file ${xo} $num ${extract_dir}"
    (procedure "sdsoc::link::extract_xo_file" line 24)
    invoked from within
"sdsoc::link::extract_xo_file $xo $count"
    (procedure "sdsoc::link::process_xo_files" line 9)
    invoked from within
    (procedure "runMain" line 12)
    invoked from within
"runMain"
    (file "/localhome/opt/Xilinx/SDx/2018.2/bin/sdxl.tcl" line 430)
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
Note: if I compile with `-t sw_emu`, it works.
I am also using an ssh terminal with no access to X-Windows. So I can't open Vivado/Eclipse project. So I have my own OpenCL/C++ project to use the FPGA.
Any ideas/pointers about how to address this? Am I missing something?
Thank you
Re: ERROR: [XOCC 60-398] sdx_link failed - OpenCL kernel
Just to clarify, this new compile and link was done outside of the below directory correct?
The intent is to not to necessarily separate the compile and linking directories, but to move all of the files outside of the 'c++' directory, so for example you would have your sources in '/home/juan/fpga-opencl-examples/cplusplus/saxpy' and compile in there.
Please don’t forget to reply, kudo, and accept as solution!
Hello @jjfumero, the error seems to indicate something is going wrong when trying to extract the .xo content. My initial thoughts would be because this processing is occurring within a directory that contains the '+' symbol. Could you try running the xocc linking outside of your 'c++' directory and see if you get the same errors?
Hello @kmorris
   I created separated directories for the source and the generated binaries but I get the same error.
xocc -c -o bin/mykernel.xo -t hw --platform /localhome/opt/Xilinx/SDx/2018.2/platforms/xilinx_kcu1500_dynamic_5_0/xilinx_kcu1500_dynamic_5_0.xpfm sources/mykernel.cl
xocc -l -o bin/mykernel.xclbin -t hw --platform /localhome/opt/Xilinx/SDx/2018.2/platforms/xilinx_kcu1500_dynamic_5_0/xilinx_kcu1500_dynamic_5_0.xpfm bin/mykernel.xo
Error:
    while executing
    invoked from within
    invoked from within
"dict with kdata {
    invoked from within
    invoked from within
    invoked from within
    invoked from within
"runMain"
Hi @kmorris  yes you were right. The problem was the directory name "c++" with the '+' symbols. By using any other name works perfectly
PS: It would be great to improve the `xocc` error messages to get this ;-)
Thank you.
Juan
