Participant enshall_123
ERROR: sdslint exited with non-zero code
When I accelerate my function by HLS, SDx report a error as follows. There are no enough info for me to understand what happened...
14:46:37 **** Incremental Build of configuration Release for project sec-sdx-proj ****
make pre-build main-build
sdsoc_make_clean Release
Building file: ../src/venus_demo.cpp
Invoking: SDS++ Compiler
sds++ -DHLS_NO_XIL_FPO_LIB -Wall -O3 -I"../src" -c -fmessage-length=0 -MT"src/venus_demo.o" -hls-target 1 -I/home/zx/zhangxiao/workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include/c++/6.2.1 -I/home/zx/zhangxiao/workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include/c++/6.2.1/aarch64-xilinx-linux -I/home/zx/zhangxiao/workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include/c++/6.2.1/backward -I/home/zx/zhangxiao/workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include -I/home/zx/zhangxiao/workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include/glib-2.0 -I/home/zx/zhangxiao/workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/lib/glib-2.0/include -I/home/zx/xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -I/home/zx/xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -I/home/zx/xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -I/home/zx/xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -I/home/zx/xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -I/home/zx/xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -mstrict-align -hls-target 1 -MMD -MP -MF"src/venus_demo.d" -MT"src/venus_demo.o" -o "src/venus_demo.o" "../src/venus_demo.cpp" -sds-hw venus_demo venus_demo.cpp -clkid 2 -sds-end -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "/home/zx/zhangxiao/workspace/zcu102-rv-ss-2018-2/zcu102_rv_ss"
Processing -sds-hw block for venus_demo
Create data motion intermediate representation
/home/zx/xilinx/Vivado/2018.2/include/ap_int_special.h:99:1: warning: 'complex' defined as a struct template here but previously declared as a class template [-Wmismatched-tags]
struct complex<ap_int<_AP_W> > {
/home/zx/xilinx/Vivado/2018.2/include/ap_int_special.h:71:24: note: did you mean struct here?
template<typename _Tp> class complex;
struct
/home/zx/zhangxiao/workspace/sec-sdx-proj/src/venus_demo.cpp:779:59: warning: multiple unsequenced modifications to 'i' [-Wunsequenced]
output_ctrl_case1:for (int i=0; i<data_trans_times;i=i++) {
/home/zx/zhangxiao/workspace/sec-sdx-proj/src/venus_demo.cpp:812:60: warning: multiple unsequenced modifications to 'i' [-Wunsequenced]
output_ctrl_case02:for (int i=0; i<data_trans_times;i=i++) {
/home/zx/zhangxiao/workspace/sec-sdx-proj/src/venus_demo.cpp:839:59: warning: multiple unsequenced modifications to 'i' [-Wunsequenced]
output_ctrl_case3:for (int i=0; i<data_trans_times;i=i++) {
Performing accelerator source linting for venus_demo
WARNING: [Linting 83-3003] Linting: "volatile" qualifier must be applied to a pointer or array type and have #pragma SDS data zero_copy! @ ../src/venus_demo.h:158:5
WARNING: [Linting 83-3003] Linting: "volatile" qualifier must be applied to a pointer or array type and have #pragma SDS data zero_copy! @ ../src/venus_demo.h:159:5
ERROR: [SdsCompiler 83-5111] sdslint exited with non-zero code processing /home/zx/zhangxiao/workspace/sec-sdx-proj/src/venus_demo.cpp for accelerator venus_demo
Please correct any compilation or sds++ compatibility issues.
sds++ log file saved as /home/zx/zhangxiao/workspace/sec-sdx-proj/Release/_sds/reports/sds_venus_demo.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [src/venus_demo.o] Error 1
src/subdir.mk:33: recipe for target 'src/venus_demo.o' failed
Thx for any help!!
Re: ERROR: sdslint exited with non-zero code
Hi @enshall_123
Is the function venus_demo_wrapper() accelerated?
Then use sds_alloc() for memory allocation
Best Regards,
Nutan
Hi @enshall_123
Please have a look at below warnings,
Please correct them else you can share the code snippet, I can suggest the change.
Best Regards,
Nutan
Hi @nutang
Thank you so much for your reply !
I try to correct these warning/error by wrapper the HLS files,  new errors happens:
ERROR: [CF2XD 83-2235] Hardware function 'venus_demo_wrapper' array argument 'bytestr_in_V' has 32832 elements, which exceeds the maximum supported BRAM depth of 16384.
ERROR: [CF2XD 83-2235] You can use '#pragma SDS data access_pattern(bytestr_in_V:SEQUENTIAL)' to map this argument to a FIFO interface.
ERROR: [CF2XD 83-2239] failed to create xd_adapter for accelerator comp venus_demo_wrapper_1
ERROR: [CF2XD 83-2009] An error has occurred during generation of the system block diagram. For more information, please look for additional ERROR messages in the console and in log files.
'bytestr_in_V'  was defined like this :
uint128_t *bytestr_in = (uint128_t*)calloc(525312/16, sizeof(uint128_t));
uint128_t   *stm_img = new uint128_t[208*208*16/16];
data_t         *src_img = new data_t[416*416*3];
 venus_demo_wrapper(bytestr_in, src_img, stm_img);
how I can alloc the space in ddr, or how to find the addr of ddr start.
Thank you!!
Hi @enshall_123
Best Regards,
Nutan
Dear
Hi @enshall_123
After changing sds_alloc() , have you done below change too?
Best Regards,
Nutan
